ziPhone?
flippen
Dec 8, 2007
39
umm ok i had a jailbroken 1.1.2 (i did it the old way downgrade to 1.1.1 and re upgrade it yes u know)
but i just restore it and want to jail break it again
so i used ziPhone (the new one i think)
first it for some reaso unlocked it (i think i clecked it accidentally)
but i just refurbresh it to 1.1.2 and clicked jailbreak
and everythin went well
but then i couldn't use edge and i couldn't download somestuff like the GBA emulator or mobilchat
what do i do?.....
flippen
Dec 8, 2007
39
but i don't want it to do alll
i don't need an unlocked phone i have ATT
themanofthedark
Jan 5, 2008
2,674
26
Boston
right. here is what you do in that case.
download ZiPhone and then press Jailbreak only.
or maybe what is the second option..?
Lava
Feb 25, 2008
31
Have you tried looking for fixes in installer? There are tons of fixes for things like edge and whatnot. Also, did you check if your edge settings are correct, i know that i had to set the edge settings on Rogers, i don't know if you have to change them if they are AT&T.
What exactly happens when you try to install GBA?
flippen
Dec 8, 2007
39
^ it said error download package faild
flippen
Dec 8, 2007
39
^ i did that
and i don't think u need any fix cause i have 1.1.2
and yes
i have try a lot of times already
themanofthedark
Jan 5, 2008
2,674
26
Boston
reinstall Community Sources, and then reboot and see if it works now.
have a good day.
flippen
Dec 8, 2007
39
it won't even let install community sources
but i did install all sources and tryed again and still same result
i think im gonna just restore my iPhone and jailbreak it the old way
