Am I the only one not using a screen protector?
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
I'm using the Glas.t tempered glass screen protector from SPG. Worth every bit of the 28 bucks it cost. It seriously is as good as having no screen protector at all. Feels the same as a naked screen and no loss in responsiveness or looks. I usually refuse to use screen protectors but I am very happy with this.
  • Like
Reactions: Tattooed Alex
Bennyboy
Jul 21, 2010
14,017
1,731
PA
Do you have that installed on the iPhone5, or is that on previous models?
rgomez
Aug 5, 2010
I have the Ultra Crystal on my wife's and mine iPhone 5's and it's great. I haven't tried the glas.t like aggieman, but the UC works great for me and doesn't cost as much.
rgomez
Aug 5, 2010
The screen protectors that are DRY applications, with no solution spray needed, like the spigen sgps, are by far the easiest to put on. I don't even bother with zagg shield-like protectors.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
Are you using any type of case? I am curious how this works with a case?
It is slightly more narrow than the screen to allow room for a case. My sure it would interfere with most cases anyhow as it is very thin. I'm using a speck candyshell right now with no issues. Have a Diztronic TPU case coming tomorrow which should work fine as well. The only cases I think it may cause issues with are slider type cases.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
Well my Diztronic TPU case came in and it was a no go with the glas.t screen protector. It pushed in tight against the edges of the protector causing it to lift from the screen. If you decide to buy this case chances are you will have to try a case out before you buy one. I'm personally more worried about protecting the screen than the body so I will shop around to find one that works with the screen protector.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
That's the same case I have. So I should be ok. Thanks for the suggestion.
aggieman
Jul 6, 2007
4,053
85
Dallas, TX
The Speck or the Diztronic? Speck works great with the glas.t protector. Diztronic is a no go unfortunately which is a major bummer for me as I've loved their TPU cases on my last few phones. The iPhone 5 one is just as nice and great fitting adding very little bulk. Hate that I won't be able to use it.
Bennyboy
Jul 21, 2010
14,017
1,731
PA
The speck candyShell. I was worried because of the side lip of the case it wouldn't fit.
theorioles33
Jul 21, 2007
925
135
USA
I have an SGP front and rear clear protector. Thats it. The back one is nice for the iPhone 5. Its a three piece.
rgomez
Aug 5, 2010
Yeah, I can't wait to get my Ultra Crystal Mix. Only have the front protector on right now. Got any pics?
theorioles33
Jul 21, 2007
925
135
USA
Here's a pic of the middle up. I had to take a picture in the mirror since I don't have a digital camera. LOL!
The fit is perfect as with every SGP product.
  • Like
Reactions: leggz2di4
lemoon
Oct 28, 2010
216
11
My brother and me are very careful too, and we don't use screen protector, only have back protector. Well, I like the feeling of fingers directly touch with my Phone.
