Engadget reveals...
iJohn
Jun 21, 2007
384
Long Island, NY
johnburke.tumblr.com
If you watch the new :25 minute video, at one point the guy talks about how users will find the keyboard easy to use if they trust its ability to correct their mistakes. I'm sure it takes some getting used to but it can't be that bad.
maclaptopuser
Jun 13, 2007
202
It all depends on what you want to use if for. As the entertainment device it's designed to be, the keyboard will see very little usage.
However if you want to use it for your emails, texting and the like, you are looking at the wrong phone.
For communications you would be so much more comfortable with a BlackBerry. Plus you would be saving yourself hundreds of dollars.
