Facebook app and Jailbroken phones
comncense
Jun 24, 2007
116
Jacksonville, FL
It seems a lot of people on the App Store's review page for Facebook are saying that the latest update for the Facebook app doesn't work with jailbroken phones. I updated Facebook yesterday when the update was released and haven't been able to login since. Anyone else with a jailbroken phone having the same problem?
larryo108
Dec 22, 2009
182
I am jailbroken and updated facebook. I have had no issues. In fact I just used it to check-in at my location.
KabaModern
Mar 31, 2008
4,549
31
Philadelphia, Pennsylvania
It's not playing nice with some jailbroken applications utilizing mobilesubstrate. biteSMS and iBlacklist are two examples. It's an issue with Facebook but the dev for biteSMS was kind enough to release a fix.
KabaModern
Mar 31, 2008
4,549
31
Ahh ok cool. I just had uninstalled BiteSMS and it worked. I guess I'll go back and check for the update. Thanks for the info.
The update won't be in Cydia until, at the earliest, Monday. However, you can manually update the one file that will fix the issue. Here is the post from the dev of biteSMS with instructions. It's very simple. Let me know if you need help.
http://forums.bitesms.com/forums/1/topics/2759
Good luck.
tdc129
Aug 20, 2010
My Facebook app still doesn't work on my jailbroken phone and I never had bitesms installed. Does anyone know of anything else that might hose it up?
KabaModern
Mar 31, 2008
4,549
31
Again, it's not just biteSMS causing this problem. I know iBlacklist has been reported causing problems. Virtually anything utilizing mobilesubstrate could be the culprit.
