I wasn't able to use iBrickr instead of AppTapp. However once AppTapp does it's thing iBrickr works as usual.
yeah that's what I'm asking. It sounded like you jailbreaked first then running right you ran appinstaller or ibrickr. It sounds like you just consolidated the steps. I just want to make sure I have this right before I make an attempt at it is all. There being quite a few posts about method in this that is.You will need to jailbreak your phone. Read the instructions and where it says to install apptapp to jailbreak you can probably use ibrikr although I haven't tested.
so I need to download apptapp on to my computer first to make this work? Then run ibrckr after everything is fully functional? Also using apptap and ibrckr won't interfere with each other when both are installed at once?I wasn't able to use iBrickr instead of AppTapp. However once AppTapp does it's thing iBrickr works as usual.
You can run both with no issues.so I need to download apptapp on to my computer first to make this work? Then run ibrckr after everything is fully functional? Also using apptap and ibrckr won't interfere with each other when both are installed at once?
OK IVE READ ALL POST IN TRYING TO DOWNGRADE MY FIRM.I wanted to say thank you to everyone who posted information on this thread. I've been reading nonstop deciding whether or not to try, and I built the courage did it, and BOOM first try it worked no problem. Installer is working just fine. THanks!
So the yellow triangle indicates you've made progress! This is a 1.0.2 symbol. Go here:guys im dying here I don't know what Im doing wrong here
heres my situation:
bought a brandnew iPhone, pulled outta the box and upgraded to 1.1.1 by accident right away before i did anything.
now I cant downgrade !
I keep gettin back to the yellow triangle saying it needs to restore?
I seriously need help!
If i successfuly downgrade will i be able to jailbreak my phone (still don't even know how to do that yet either) can i unlock and use anysim?
