Great battery life on iPhone 4
Chancellor
May 28, 2011
280
24
When I had the iPhone 4 it would last me about a day, my friend has an iPhone 4s and hers lasts her two days hehe.
MoneyMaker79
Dec 15, 2008
5,386
340
When Jailbroken, you can have those apps close when you exit them, or you can manually close each one that's left open.
MoneyMaker79
Dec 15, 2008
5,386
340
Mobile connection doesn't use a lot of battery life. I lock my phone for hours when not using it, and it doesn't use any life. Even at night, it may only lose 7-8% overnight when on but not in use.
  • Like
Reactions: Leslie Bass
MoneyMaker79
Dec 15, 2008
5,386
340
Same here. Try a full restore through iTunes and maybe even set it up as a new iPhone. That's up to you. Since you aren't Jailbroken, there can't be anything else causing your battery life to be that bad unless you're just using your Music app a lot, and specific other apps that can cause battery drainage.
If it's a serious drainage, maybe get them to look at your battery? I doubt that's the cause of it though. Usually battery lasts at least 12-15 hours or more depending on how you use the iPhone.
Axne1
May 17, 2012
41
Facebook is a battery killer.
Worst app on ios to this point...
RUcollegeBoy
Oct 23, 2010
19
Jersey Shore, NJ
I've noticed my iPhone 4 battery is horrible over the last few days. I was having work done on my car and haven't had my car charger to juice up halfway through the day. I think the use of gps is what's killing mine though. Today it died at 1pm. I almost died with it.
RoofMonkey
Jun 21, 2010
8,940
1,984
Yes, the GPS is a huge battery drain!
davdialan
Jun 23, 2021
Tips for you people experiencing a drop in battery life:
This is what I have found,
-close out apps once a day
-run brighness half way with auto dim on
-set you email to fetch hourly
-keep wifi and Bluetooth off unless your using
-use wifi instead of 3G when you can
-immediately close out gps based apps when you are done
-do not charge the battery until it drops below 20%.... I had an argument with an Apple rep about this who told me it doesn't make a difference. That's bs, and I know it for a fact. You won't damage the battery charging it at 50%, but expect the battery life to be shorter that day.
-make sure you let the phone charge for 2-3 hours after it says 100%.... it trickle charges
I can leave mine over night not charging and it will only lose 2%-5%
More: giá thay pin iphone, giá thay pin iphone 4
Anyone using iphone 4 now? I have an iphone 4 memories that still exist to this day
