At least it will bounce when it falls, get some air under it and have a safe landing. GR8 ideaI'm going to use this stuff...
I'm full of ideasAt least it will bounce when it falls, get some air under it and have a safe landing. GR8 idea![]()
Isn't that the material used to make the iPop cases? HahahaaaI'm going to use this stuff...
I hope they're all good wholesome, virginal ideas. Fresh and clean as the driven snow. Oh, what am I saying, of course your ideas, that you are so full of are brimming with honesty, virtue, strength, and awesomeness.I'm full of ideas![]()
I hope they're all good wholesome, virginal ideas. Fresh and clean as the driven snow. Oh, what am I saying, of course your ideas, that you are so full of are brimming with honesty, virtue, strength, and awesomeness.You're just an all-around GR8 guy who's full of ideas! Awesome!
The black Switcheasy Trim is in my weekly case rotation with my SGP Neo Hybrid. Great case.I ordered the black switcheasy trim (http://www.switcheasy.com/products/TRIM/TRIM.php) - got top reviews on ilounge.com, is still slim, but covers the back as well. I got the white iPhone to pop in the black case which should look nice. The case is only $23 with shipping, comes with 2 screen protectors, a piece to put in the charging port, and a piece to put in the headphone jack to protect when not using, a little stand to prop it up, etc. so its well worth the cost. And the back piece is a semi translucent so you still see the Apple which is nice. It comes in a bunch of colors: blue, black, white, pink, green
Yeesh, if you give otterboxes to your friends that you don't like much, what do you give your friends that you do like?I will switch from naked to case
I have a few cases and who knows may get a few more
I use the Lifeproof at the moment. the OtterBox I will give my friend I don't like much. Who knows what I will find while out and about and or surfing the net.
Yes, slightly, so it may not work with cases that are tight fitting or have a lip around the front like the Otterbox. I started out on the iPhone 4 with an invisibleShield full body coverage and added a bumper when we got the freebie, and it fit with a little wiggling, but it tore up the edges a bit.I had an incipio than an frog lux lean took it back and got the purple otterbox and like it just need a screen cover was thinking if a zagg full cover fir scratches but will it make the phone thicker?
