HTC Weather on iPhone ( project )
katra
Jun 26, 2007
229
For Wallpaper issue's...Just Remove the "Wallpaper.html" file from the theme.....
your springboard should now show your wallpaper...!:laugh2:
teambash
Aug 20, 2008
142
Ok I have some questions about this..
When I receive a phone call and the image of my friend shows up this app is overlaping my friends image. Is this suppose to happen?
katra
Jun 26, 2007
229
how do I change Boston to Toronto and farenhit to celcius
In file ConfigureMe in Private folder change nest stroke to your city:
for city...
Code:
var locale = "Miami, Florida"
...or wherever you live...
for Temp ...
Code:
var isCelsius = false
"true" if you want celcius, "false" if you want
Farenheit.
teambash
Aug 20, 2008
142
Can you send me that configure me file with the changes I want. I can not seem to open yours.
katra
Jun 26, 2007
229
im on windows...i don't use SSH or SCP..
i use iPhonebrowser 1.8.1 ..google it...and download :)
click on "go to locations" select "winterboard themes" then just drag and drop the folder or files ....:)
katra
Jun 26, 2007
229
Thanks man but I can not open that folder.
are you on a windows ?
if you are... just right click on the "configureme.js" file and select "open with" and select wordpad.
this should display the codes...
katra
Jun 26, 2007
229
katra is there anyway u can help me out... or anyone else... i cant get this to work...
Try unchecking everything else except my theme... tell me if that works..
i think what ever other theme you have checked might be stoping it from showing.....
let me know...
