HTC Weather on iPhone ( project )
teambash
Aug 20, 2008
142
Ok I changed mine to Toronto, Ontario and all I get is the circle thing loading and no image help please..
kr3st
166
Winter Park / Orlando, FL
Toronto, Ontario
my zip would be m5r1c1
don't know country code
help please
Try just using that, it should work. I live in Winter Park, FL and I use 32789 which is my zip code and it works fine for me.
Try pasting this in your configureMe.js file.
// WeatherWidget.theme
// Produced by Adam Watkins (http://www.stupidpupil.co.uk)
// The location field should be a relatively machine-legible string
// if using the default, Apple/AccuWeather parser (originally from Leopard's Weather.wdgt)
var locale = "m5r1c1" //e.g. 'Defiance, Ohio'|'Moscow, Russia'|'Ledyard, AT'|'London, UK'
// Set to 'false' if you'd prefer Farenheit
var isCelsius = false //true|false
// Use 'Real Feel' temperatures where possible, taking into account Wind Chill, Humidity etc.
var useRealFeel = false //true|false
//Enable Wallpaper and/or Lock Screen
var enableWallpaper = false; //true|false
var enableLockScreen = true; //true|false [Currently, it is suggested that the lockScreen is disabled.]
// Supplied styles are 'originalBubble', 'myopia', 'iconOnly' and 'split'.
// (Add your own to the CSS folder!)
var stylesheetWall = 'katra' //'originalBubble'|'myopia'|'iconOnly'|'split'|'oneLine'
var stylesheetLock = 'katra' //See above.
// The only supplied icon set is 'klear'
// Images must follow the same naming schema as the 'klear' set (borrowed from KWeather)
var iconSetWall = 'katra' //'klear'|'tango'
var iconExtWall = ".png" //'.png'|.'gif' etc.
var iconSetLock = 'katra' //See above.
var iconExtLock = '.png' //See above.
// The other available source is 'yahooWeather' which for the 'locale'
// requires a US zip or location code (e.g. UKXX0085 or CHXX0008) from http://weather.yahoo.com
var source = 'yahooWeather' //'AppleAccuweatherStolen'|'yahooWeather'
// Please endeavour to set this to a sensible value if you really must change it...
var updateInterval = 30 //Minutes
smittylube
Feb 19, 2008
255
Silicon Valley
OK I am going to give it a try & install it... wish me luck- or better yet hold my hand.
I removed the lock screen widget as suggested in one comment from Lincoln.
smittylube
Feb 19, 2008
255
Silicon Valley
Darn vista...
I try unzipping and it wont import the png. format is wrong error.. Then I try & open the JS file & it opens in dreamweaver.. I guess that is fine to edit the script file Yes? I can see the png files in the download folder but I am trying to keep it organized in a theme folder & it wont drag & drop or copy paste.....
I am trying just to first get it on my laptop then go from there.
Steve
smittylube
Feb 19, 2008
255
Silicon Valley
So I dl winrar and was able to unzip to my themes folder but I get this error
>>>! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\LockBackground.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\LockBackground2.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\blowing_snow.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\flurries.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\freezing_drizzle.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\hail.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\light_snow.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\showers.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\sleet.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\snow_showers.png. The file is corrupt
! D:\iPhone themes\Katra_s_Weather_HD.theme.zip: CRC failed in Katra's Weather HD.theme\Private\Icon Sets\katra\windy_blustery.png. The file is corrupt
What do I do now?
smittylube
Feb 19, 2008
255
Silicon Valley
OK this time it all came through.. I can see the screen shots, etc.
SO for Silicon Valley do I use a zip code or San Jose, Or Mountain View?
Sooooooooooooooooooo Exciting :)
BTW I just tried to DL it again from RS. Then I guess it unzips to a folder. I just dragged the whole folder 'katras_ weather_hd.theme into my themes folder (on my LT). Hope this might help the other helpless folks like me :)
