iFuntastic 3 Released!
iLLGT2
Jul 26, 2007
211
NY/LI
No You do not have to fully restore it will work "untested" on another forum i read that the background image was acting a bit funky.
Hmm, so if i'm not messing with that I should be fine then right? Anyone have the video for specifically mac users and hacking their phone, tutorial like the guy with PC's?
akophone
Aug 1, 2007
300
Well I must be really dense...I changed the names...and they went back to the original names: mobileipod etc....
there must be something I am not doing and I can't seem to figure it out. Any other suggestions on changing names?
The best way to do this now is this:
Make sure iFuntastic is closed. Go to your HD>Applications>iFuntastic Support (folder) and open a text file called HomeScreenArrangement.txt.
You will now see a list like "com.apple...." . Type a new name after the "newName=" replacing the default name apps to your custom name. Make sure there is a space after the"=" sign.
When finished, save your changes.
Now open iFuntastic. Go to Home Screen. You should now see the updated app names, yes? Now click "Update iPhone". Your iPhone will prompt you to "slide to unlock". There you have it!:laugh2:
nobbie
Jul 23, 2007
282
My friend was playing with this last night and managed to brick his phone. He did a restore and now he doesn't have Edge. I'm waiting for a bit before jumping on the iFuntastic bandwagon!:mad:
The Toddfather
Jun 23, 2007
161
I'm a total n00b when it comes to mods, but I gave it a try last night. It was simple to do and now I'm having fun playing with the features. I can't quite get changing the logo name to a personal one, has anyone had any luck?
sele
Jul 17, 2007
75
I can't get it to work. The software keeps timing out and can't modify my phone at all with this.
I was having this problem as well, but it turns out that iFuntastic was waiting to close iTunes (which was not opening when iPhone was connecting). Once I opened iTunes, iFuntastic closed it immediately and then went to working on my iPhone.
RTpics
Jul 19, 2007
80
Malibu CA
you have to make 2 .png files size 65x20 name the ie: xxx1.png and xxx2png put them in the same folder this should then work, both files will be carried over into ifuntastic3 when you select them.
akophone
Aug 1, 2007
300
kwan
Jul 7, 2007
88
Does anyone know how to install 3rd party apps using ifuntastic 3.0?
Ever since unshackling I cant get ibrickr to install 3rd party apps.
RTpics
Jul 19, 2007
80
Malibu CA
If he had bricked his phone he would not have a phone, let alone EDGE
The Toddfather
Jun 23, 2007
161
How do I make a .png file?
Thanks,
Todd
DeeRector2
Aug 30, 2007
54
Changing names for the APPS
Thanks a lot for the help. This worked!
edwardlotz
Jan 29, 2007
27
blank space holders on the screen and issue.
When I mod the screen...it looks great....I didn't put the page 1,2,3,4 buttons because I am not using these extra screens...but the problem I am seeing is that when you touch the empty space holder...the iPhone things its a program and trys to start something....
is there anyway to turn these blank spaceholders into blank area and not active ones?
Also I am having problem where ifuntastic will stop making changes on my iPhone. I made screen changes, added some ringtones and then I tried to set my att logo to iPhone and it wouldn't make the change on the phone. Even though it beeped/chimed that it did.
Any thoughts on these issues.
DeeRector2
Aug 30, 2007
54
yes I have the same issuer with the active live spots. I don't know how to fix that, as far as the other issue. Thats happened to me a few times to. I just rebooted the iPhone and rebooted iFun. Usually that works. Its worked a bunch of times so try it out.
DeeRector2
Aug 30, 2007
54
iFuntastic is for MACS, but use iBrikr. Thats for windows.. Everybody else is using it and loves it. Thats probably the best program out right now.
any other software similar to this one for windows user? or any Window version?
iLLGT2
Jul 26, 2007
211
NY/LI
Best out for pc's your saying right? I have the option to use either or, is funtastic or ibrickr better ?
DeeRector2
Aug 30, 2007
54
iFun or iBrikr
I haven't used i Brickr. but seen it. It seems a lot better than iFun. iFun is extremely limited and not perfected. Very glitchy. Go with iBrikr. - DeMo
joe
May 5, 2007
1,113
I'm being a complete idiot I'm sure. How do I install a native app? iFuntastic has a way to drag and drop an app into the iPhone but where do you get an app? Maybe someone can just give me a quick 1,2,3? Sorry for being so lame! :laugh2:
Kinda surprised no one has this answer. Seems like someone knows how to do this and should be able to give me the clue I need. I think kwan is asking the same thing.
DeeRector2
Aug 30, 2007
54
iFun is weird man. I got a program workin once using it but thats it. I cant get them any more.. Im trying to use AppTapp now, and im having issues with that as well.. All this stuff is very confusing.. I just wish Apple made there own software that allows us to mod our phone.. Going through all this nonsense is ridiculous.
