iPhone 7 iPhone 7 iOS 10.1 issue
Status
Not open for further replies.
MoneyMaker79
Dec 15, 2008
5,386
340
I have an iPhone 7 I have an issue with iOS 10.1 every time press on lock button and slide to eight of iPhone to get to widget it's sometimes it gets jammed it won't let me slide to the left is this iOS bug ? Never happens before
Hmm I am unsure about that as I don't have an iPhone 7, but if you're just talking in general then I just noticed as well a slight "lag" when swiping left or right when on lock screen. I just need to quick swipe. If this is what you're referring to, then It's no big deal...I wouldn't see this as a bug in my opinion.
  • Like
Reactions: alexrat1996
alexrat1996
Jun 23, 2016
323
19
Even if I swip left I get the lag I have to swipe two time is this a software bug to make sure and have a correct answer
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
I'm not experiencing any lag when swiping right to get to my widgets. I'm using an iPhone 7 Plus. I wonder if it's peculiar to the iPhone 7, similar to how the app animation closing jitter seems to be limited to the 7 Plus.
alexrat1996
Jun 23, 2016
323
19
Are you sure you're performing the swipe correctly? Is the page moving at all when you try to swipe right, or is is completely stuck until you try a second time?
It swip but at points kick me back to the same screen it lags and it works second time and I''m sure I'm swiping correctly here video and it's does get stuck at points I did restore in iTunes as new same issue here video
Napoleon PhoneApart
Jun 19, 2007
33,493
4,417
Upper Marlboro, MD
Okay. I see what you're talking about now. It's sliding to the left that's hanging up. Mine does the same thing. I tried turning off Reduce Motion in Settings but that didn't help.
5,405
iOS isn't registering your gesture because it's not a long enough swipe. Try doing longer swipes. Start at the far right of the screen and swipe to the far left.
5,405
I already tried this and it didn't work consistently.
It's working consistently for me. Perhaps it will for Alex. I am able to replicate his problem with short, light swipes as he does in the video and stop it from happening 100% of the time when I do wider swipes the first time.
Status
