Jailbreak done, BiteSMS issue
Buffy
Jan 20, 2008
2,216
Limera1n jailbreak went smoothly, everything works well except the one app I want the most.
Installed BiteSMS and rebooted my phone. Every time I open the BiteSMS app, it automatically exits. I've uninstalled and reinstalled it, same result. Any suggestions?
Buffy
Jan 20, 2008
2,216
Well, I can always restore and get the cleaned up version. You know I'm usually the last to take the leap, but I'm just THAT desperate to get my BiteSMS back! All my other Cydia apps work just fine. Argh!
GSXRMike
Jun 21, 2009
565
14
Saint Augustine, FL
I use QuicklyReply 1.6.4-3. Works great even after LimeRa1n. Maybe not as many functions as BiteSMS but I don't need all that other junk. My main reason is so I can text back without having to close the current open application.
Buffy
Jan 20, 2008
2,216
I guess I can use Quickreply if I can't get BiteSMS to work. Does it allow you to set a delivery time for SMS? This is the feature I like the most; I can reply to texts in the middle of the night and time them to be delivered at a decent hour the following morning.
GSXRMike
Jun 21, 2009
565
14
Saint Augustine, FL
Nope.. None of that. Just allows you to text back over open apps. When you receive a text, it has 3 options instead of 2. Close, View, and Reply. Close and View are the same as a stock phone but Reply pops up the keyboard right there so you can respond back.
Buffy
Jan 20, 2008
2,216
Okay, I think I remember trying that one last time, and deleting it for BiteSMS. I just can't understand why Bite isn't working when the other apps are. If I can't get it to work, I'll probably just restore, as I can see already that my battery is draining more quickly since I JB.
Edit: Could it have been something that went wrong in the jailbreak, or is this likely a BiteSMS issue? Anyone?
Woody dog
Sep 22, 2009
107
Lancaster,Ohio
It did the same thing to me. I just hid bite with sbsettings and use stock text app. The quick reply and text from lock screen still work. They will have an update they are very good about them.
craiggiarc
Jan 20, 2009
421
32
Smooth as silk here too, found the BiteSMS fix too but was beaten to get it posted here!
BlindSpoTT
Dec 16, 2008
1,092
York, PA
You jumped the gun IMHO. I'm waiting for a cleaned-up version, maybe even until after I swap my phone for one that doesn't have the proximity sensor issue. I'll pull the trigger late this month.
wait, so 4.1 doesn't fix this? mine is BAD! i cant hold my phone on my phone on my right shoulder without hanging up. actually ive done that just turning my head the wrong way...
imotionb18
Jun 15, 2010
458
Houston, Tx
I was having a huge issue with this. That's the main reason I went ahead and used limera1n. 4.1 is supposed to fix the proximity issue. 4.1 seemed to have fixed my prox problems as far as I can tell.
5,405
Limera1n is supposed to be really buggy.
Some people have had trouble jailbreaking with it, but that happens with every jailbreak tool. Once the phone is jailbroken, stability and jailbroken app problems are probably no more likely to occur than they would with any other jailbreak method.
limera1n worked fine for me. iRealSMS is working as well.
Edge1978
Feb 7, 2009
245
4.1 completely fixed my prox issue. I used to always put the person on hold or mute, not anymore.
