Making the ring LOUDER! I can barely hear it.
MotoGreg
Aug 27, 2007
To max the volume of your external speaker... on your phone go to settings/ipod/volume limit/lock volume limit/enter a volume limit code/ then enter zero in each of the four boxes and then re-enter the same thing.
Flyingstar
Jul 29, 2007
343
So. Cal
You must mean INTERNAL speaker right? Anyway I did that and it did not make the alert tones any louder.
MotoGreg
Aug 27, 2007
Yes, internal speaker. That just "turns the speaker's volume knob" all the way up... Which is still weak. I'm going to edit a ringtone volume in iTunes like someone posted already when I get a chance... It works on my iPods so it should work the same for the phone
akophone
Aug 1, 2007
300
I made this Garage Band ring even louder by using an audio editor (like Fission) and normalizing it, making sure that the maximum level is reached without, of course, reaching the distortion level. This is my "must-hear-this-phone-ring" ring tone;)
hiker
Oct 8, 2007
Suggestio
The only ringtone I want for my iPhone is one I can hear all the time. User akophone found such a ringtone named Cell Phone Ringing that is awesome…see his comment below.
Unfortunately it appeared that the only way to use it was to hack the iPhone (which I refuse to do); or use other Mac software like iToner. Then I ran across something very simple...rename the extension to AAC then M4R then double-click the M4R and presto it appears as a ringtone in iTunes. Sadly this was disabled by an iPhone update. Then apparently re-enabled in 1.1.2. Anyway, it works today. :cool:
For those who want a really loud ring tone and has a Mac, you can find it at Library>Audio>Apple Loops>Apple>iLife Sound Effects>Work-Home>Cell Phone Ringing.
I imported this audio file to iTunes as mp3, dragged it to iFuntastic v.3 Ringtone page and voila! This ring is super loud (sounds almost like the ring tone used in the iPhone commercials). I heard it even while shopping at Abercrombie and Fitch! Hope it works for you :)
akophone
Aug 1, 2007
300
Try the package called "SendSong" from the Installer. You need to convert this file to m4a in order for this to work with as a ringtone. Before installing, click the "More Info" on the bottom of the Package page so that you'll know what you're dealing with. Good luck!
hiker
Oct 8, 2007
Is there any way to use the "cell phone ringing" ring tone using iTunes on a pc and without hacking the iPhone?
hiker
Oct 8, 2007
Holding Out
I am still hopeful that Apple will open up on ringtones; especially there own like "Cell Phone Ringing". We can not hack ours.
hiker
Oct 8, 2007
Unfortunately, you're not alone with the volume issue during a call. The Apple iPhone forum is flooded with users who are experiencing the low volume problem (both from the earpiece and the speaker phone). As of now there is no fix for this. There is, however, a 3rd party fix being tested at this point.
Thanks for your previous support on ringtones and sending me Cell Phone Ringing. I used the renaming method to convert the Cell Phone Ringing tone
which brings me to my question. Will software version 1.1.3 disable my ringtone? Thanks again, --Ed
mikehtiger
Nov 18, 2007
11
I know this is hard to believe but I did it yesterday and it worked amazingly well... In front of the speaker there is a dust cover that restricts the sound... I have heard of people saying they just poked through it using a needle poking through the little speaker grill holes, I am not that cavelier though... I removed the antenna cover (the black part on the back) and peeled the dust cover off (its not glued there very well) and now my iPhone outpreforms my buddy's SYNC by a lot as far as volume. I would say it is at least twice as loud.
C
Chez10
Guest
when you take the back cover off and then put it back on is it still on there tight?
KNK
Jul 22, 2007
2,391
Stevenson Ranch
When you took the cover off and put it on does it have marks. They say Apple will void your warranty when you do that.:eek:
mj2320
Jan 19, 2008
90
yeah, it would deffinatly void warranty because you are toying with the housing of the iPhone
