mod after update
FouReYez
Jul 21, 2007
9
when i use jailbreak it gets to the hold down for 25 sec part. i do all of that and wait for the connect to iTunes screen. than i release the buttons. after doing that it says sending more files... booting iPhone... than it says that i need to learn how to hold it longer. i've held onto the buttons even after the connect to iTunes screen and it still says it. what am i doing wrong? i'm on windows btw.
jgolden
Jul 19, 2007
I had no issues with Jailbreak/Monanza (sp) after my update this morning...Just a bit of a PITA to upload everything again...Drag and drop is too easy.
princess_80854
657
My update went fine as well. It's a bummer to have to do the WHOLE process over again. But, at least Manzana makes it a little easier.:)
ikecomp
Jul 29, 2007
11
I'll probably wait till the first big update before I do anything. Honestly, I haven't read anything in the update docs that would warrant me updating my phone. There are a few bug fixes for the safari browser but nothing application or feature wise thats enticing enough for me to go through the whole modding process again...anybody else feel the same way?
ryme27
Jul 24, 2007
Jailbreak
Is there a new version of jailbreak for the iPhone that i need to download in order to mod with the new update or can i use the same jailbreak as before?
thank You
princess_80854
657
thank You
You should be able to use the same one as before. There is no new version. It worked for me and I haven't had any problems.
Lazarus
Jun 6, 2007
380
Miami
so princess can you give some detail as to what happened after you updated. What did you have to do to mod again? and was update worth it?
jptolife
Jul 15, 2007
645
New York City
iFuntastic works like a charm! I already got all my ringtones back to my phone and my custom carrier logo too, all without having to type anything! this is great.
mogz
Jun 27, 2007
116
SF
If anyone here is using windows and still able to mod it after the update, please explain how...
princess_80854
657
I'm still able to mod.
You need to follow the same steps you took the first time. But remember to replace the iTunes update software with the new one iTunes just downloaded with the 1.01 update. Change the extension to .zip format. Extract everything to your modding folder, overwriting the previous files when prompted.. Then run jailbreak. The one you already have should work as there is no new version available. Choose your modding program of choice and away you go.:laugh2:
mogz
Jun 27, 2007
116
SF
I did just that and jailbreak hangs on 'booting iPhone'.
I just read on the iphone-dev forums that someone is modding again after the update with the 1.0 files...:confused:
Flyinb
Jul 9, 2007
23
www.400N.com
Modded iPhone OK after Update
I have modded my phone prior to the update from Apple, after the restore and update, it too about 10 minutes to mod my phone back to the way I had it.
I had to run jailbreak
iPhone Interface
manzana
All worked great no issues.
even sync with Itune after remod and no probs
mogz
Jun 27, 2007
116
SF
Got it working!
I kept all the files from the 1.0 and 1.01 updates.
Leave the 1.0 files there, and overwrite with 1.01 files. :)
princess_80854
657
Got it working!
That's what I just told you in my post.:laugh2: Either way, I'm glad it's working for you!
edw1nk
Jul 7, 2007
24
i left everything the way it was from version 1.0 and ran jailbreak just fine. all mods were done with no problems. btw, im using manzana on vista
