iTunes on the phone or iTunes on the computer? If on the phone, it puts purchases in a playlist titled "purchased on XXX iPhone:.....When buying a song in iTunes, it does not put it in the "Purchased" playlist.
not here...only phone bug i have is after making a call the volume adj pop up, pops up for a second then fades...is nobody else getting a problem when dialing a number directly from the contacts app... open contacts from the springboard. Then pick a contact, dial a number and contacts seems to close, a blank window opens then the dial screen shows. Then when you hang up the same screen shows for a second then disappears back to contacts screen?! Anyone?!
I found that when you hold the icon to initiate the moving procedure (icons start to wiggle), to select an icon to move you have to keep your finger on it for about a second to select it......then you can move it. If you just try and sweep the icon (before it "grabs") it won't move....Won't let me move icons!
What broke the camel's back?Couldnt take it anymore---reverted back to 2.2.1!
Experiencing same thing...I close phone book and re-open works fine thenis nobody else getting a problem when dialing a number directly from the contacts app... open contacts from the springboard. Then pick a contact, dial a number and contacts seems to close, a blank window opens then the dial screen shows. Then when you hang up the same screen shows for a second then disappears back to contacts screen?! Anyone?!
Just the lagging and the crashing. Killin me! Now I cant revert to 2.2.1, stuck in recovery mode on my mac.What broke the camel's back?
Thank you -that workedI found that when you hold the icon to initiate the moving procedure (icons start to wiggle), to select an icon to move you have to keep your finger on it for about a second to select it......then you can move it. If you just try and sweep the icon (before it "grabs") it won't move....
~S
