Settings-general- passcode lock on- create one and then at the very bottom it will say erase data after ten failed attempts, click [on]How do set the data erase for failed attempts?
That is not really the point.Never have used a passcode in three years.
Using one will not stop someone from stealing an iPhone since all they have to do is restore the phone and it can be used again.
Yes I edited my wallpaper so my text is visible from the lock screen, and with the passcode entry box up.You put ICE on Lock Screen by creating a photo with text added?
My bad, didn't mean to thank you lol.I use the passcode however its not just 4 digit number I have mine set for both letters and numbers and it comes on after 1 hour of inactivity.
Do you have a source for all this info?Here is a bit more info regarding the passcode lock...
Even if you don't have "Erase Data" set to on, anyone trying to get into your iPhone still essentially only has 10 attempts.
Once you have entered an incorrect passcode 6 times, the iPhone will prevent trying again for 1 minute. If you get the 7th attempt wrong you must wait 5 minutes. Get the 8th attempt wrong, you wait 15 minutes, then 60 minutes if you get the 9th attempt wrong.
If you get the 10th attempt wrong and you don't have the passcode set to erase data after 10 failed attempts, the iPhone will still be locked out from any further passcode attempts. You must use iTunes, on the same computer you sync to already, in order to unlock it again. So there is a measure of security even if erase data is not turned on.
If you do have "erase" data set to on, it will happen after that 10th attempt. But if you were worried that perhaps your 3-year-old nephew might randomly punch numbers into your iPhone's lock screen, and wipe it out in under a minute, that won't happen.
Moreover, on iPhone 4's and 3GS's data isn't actually "erased." What it does do is remove the encryption key on the iPhone, so the data is essentially inaccessible. On the 1G and 3G iPhones, which lack the hardware encryption of the 4/3GS, the iPhone literally wipes over every bit on the disk image to erase it, a process that can take hours to complete.
Finally, will the passcode lock-out prevent, say, an FBI forensic expert, from getting to your data? Or a good hacker? Probably not. But for most of us here I'd venture to say our iPhone is not likely to end up in those hands. And I would never argue that just because there is some chance your data can still be retrieved that there is no point in using this feature.
Michael
I have known about the passcode lock timeouts from actually testing it--been a long time now.Do you have a source for all this info?
I've hit the 'Thanks' button accidentally a couple times, too. You can remove it.My bad, didn't mean to thank you lol.
The emergency call feature is not really ICE.... ICE is one or more of your numbers to call should you be hurt, or if your iPhone is lost and found by somebody (who wants to get it back to you).Okay, I hate to sound stupid, but I'm needing a little more on the I.C.E. stuff. Mine is just default I guess; its locked but the I.C.E. option is at the bottom right so someone could still call or what not if my head was bashed in and I needed an ambulance. It sounds like you guys are talking about just the text "In Case of Emergency" without actually having the option for someone to enter it? Am I confused?
Oh man, that's awesome. Thank you! (Not to be removed... haha)I've hit the 'Thanks' button accidentally a couple times, too. You can remove it.
