Just one day after the relase of iOS 4.0, the Dev-Team has done it once again. Not only did they release an unlock tool the day iOS 4 came out, they have now released a brand new version of PwnageTool for creating custom iOS 4.0 firmware packages so that those with the iPhone 3GS can get in on the action of being jailbroken.
As per usual, the same instructions apply that have always been the case with PwnageTool. Follow the onscreen instructions just as they say. Within a few minutes you will have a custom firmware package to install, and your best friend, Cydia will be there waiting for you.
If you have been tinkering with the unofficial release of PwnageTool 4.0, we strongly urge you to restore and use this version instead as the leaked version did not include patches that are required for ultrasn0w unlock.
I first JB using Geohots JB...then had to upgrade to 3.1.3 and i used spirit (currently have a 05.12.01 baseband now).. Can I use this to upgrade mine to 4.0 & JB since I originally jb with blackrain?As advised, you shouldn’t have upgraded your devices if you have previously relied on our tools for hacktivation and/or a carrier unlock.
Each supported device has few different scenarios that users need to consider when performing the upgrades, you need to check below and perform the upgrade in the particular way that matches your current device state.
NB: With PwnageTool 4.0 certain devices are not supported this is because they are not supported in iOS 4.0 or they are not supported by our software.
iPhone 2G - not supported
iPod Touch - not supported
iPod Touch 3G - not supported
iPhone 3G
If you have a Jailbroken iPhone 3G at 3.1.2 (but not jailbroken with Spirit) then you should create the ipsw with PwnageTool 4.0 and restore from recovery mode or DFU mode.
If you have an out of the box iPhone 3G you should restore using a PwnageTool 4.0 ipsw using DFU mode.
If you have a Jailbroken 3.1.3 iPhone 3G it is very possible that this can fail from recovery mode, if this failure happens you will need to restore using DFU mode.
IMPORTANT! Whenever you need to enter DFU mode, you will need to do so using PwnageTool.
iPhone 3GS
Summary: PwnageTool only works on previously jailbroken 3GS devices with the old bootrom.
If you have a Jailbroken iPhone 3GS with the OLD BOOTROM and you DID NOT use Spirit to jailbreak then you can create the ipsw with PwnageTool 4.0 and restore with recovery mode.
If you have an iPhone 3GS with the NEW BOOTROM this is NOT supported by PwnageTool 4.0
iPod touch 2G
If you have an iPod touch 2G that is jailbroken (but not with Spirit) then you can restore using recovery mode.
Baseband Unlock
iPhone 3G and 3GS baseband unlockers (those who rely on ultrasn0w to make phone calls) should always be very wary to update their firmware, however our Ultrasn0w application will unlock all recent (including the current) 3GS and 3G baseband firmware versions, once you are jailbroken using PwnageTool 4.0, install ultrasn0w from Cydia and you’ll be unlocked.
Remember! This baseband unlock situation is rare, should you upgrade your iPhone blindly at the next iOS release please don’t expect an unlock - but for now you are OK (whatever state your baseband is in).
