Random Reboots
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
I removed the Message Id tweak. Let's see if that stops the random boots. I think it happens more when I go to open the Messages app. It just happened before I removed it.
MoneyMaker79
Dec 15, 2008
5,386
340
I've had it happen even after removing that tweak, but then again I've had it happen in other apps too. Also has happened with my phone locked. :p
EverythingApple
Jul 28, 2010
3,867
223
North Jersey
Use iFile to backup and delete /var/mobile/Library/Caches/com.apple.LaunchServices- 134.csstore. The last three digits might be different from mine. Do a full reboot after deleting the file. Some of your apps and photos will temporarily disappear after the reboot, but don't worry about this. They will reappear a few seconds later.
And, @Napoleon PhoneApart Lowpowermodestatusbar tweak update. Says big bug fix. Maybe that's the random boot. I updated. Let's see if the reboots stop.
5,405
Okay, I just did it. Now what's next? And what do I do with the backed up file?
So you deleted it and did a full reboot, correct? Now you use the phone for a while to make sure the problem is resolved. The backup was just in case you ran into problems.
