removing invisible shield question
radmonkeyx
Jul 12, 2007
77
Irving TX
i have the invisible shield on my 3g iPhone screen and it seems grainy. if i take it off, can i just spray it again and put it back on?
i was hoping this might take some of the grainy look out. i cleaned the screen and it was spotless before i put it on. i followed the directions it came with. i am at work so the answer might be on the box at home, if so sorry to junk up the forum.
thanks for any help
aq.timmy
Aug 3, 2008
23
Grand Rapids, MI
No, you can't reapply it. You will need to buy a new one.
If something happens to the IS, though, you can request a new one for no charge from Zagg and send in the old one... but you still will need to pay shipping and handling.
radmonkeyx
Jul 12, 2007
77
Irving TX
ok, thank you. are they all a little grainy in some spots? i really notice it when i am on a light colored screen.
i hope "grainy" makes a little sense in how i am trying to describe the look
