RoadRunner eMail from iPhone?
Ryukyu
Jun 15, 2007
101
Sounds like the same problem I'm having with Charter Communication. I can send emails. But not receive.
Actually, yours is the opposite problem. We are receiving just fine, but cannot send over EDGE. Can only send over WiFi.
Ocala
Jun 14, 2007
79
Ocala, FL
I don't get it. I have the same problem - the thing is, I have been using the account in my Nextel phone with the same settings with no problem for over 3 years.
Apple4me
Jun 27, 2007
1,491
124
Phoenix, AZ
Been on the phone for almost an hour with Apple. I've been escalated two times and the 3rd level guy is trying hard, but he doesn't get it yet.
I'm seriously ready to pack up the iPhone and take it back to Apple. Between this outgoing email issue and pathetic AT&T/Edge coverage here in Phoenix, I am ready to throw up my hands and wait for a few months for these issues to be addressed. As it stands right now, this iPhone simply can't replace my Blackberry for my daily use in running a small businesss.
invincible569
Jun 30, 2007
79
Thats because they permitted that IP range from Nextel, Blackberry, etc since they are popular. Now the iPhone is a new device in town which needs to be enabled from their end.
Someone call in to Time Warner and have this requested so we can relay off of their servers. It's going to take some pushing since their admins may reject the idea at first, but with popular demand, we can make this happen.
tadrewcook
Jun 22, 2007
61
Honolulu, HI
I agree with invincible. The iPhone is brand spanking new, and it simply appears to be fact that this thing is going to virtually explode onto the cellular/smart phone market. If all of these IPs will address the issue with blackberrys, then I would def imagine they will comply with iPhone users' gripes. It's not a big deal personally. In the meantime, I just work around by sending through my Gmail.
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
Same issue here!
When I'm on wi-fi, the outgoing SMTP server for RoadRunner works fine (of course) - as this is the same setting as my desktop Mac.
Of course when I leave wi-fi and go to Edge - that server is no longer accessible as the outgoing mail server, so the SEND option fails every time :(
I called Apple tech, and they gave me a working outgoing Email server for the Edge network
I just used cwmx.com (no SMPT or any other prefix - just cwmx.com) as the outgoing server name.
This works to allow Emails to send when on Edge, but of course now doesn't work when I'm back on the home wi-fi! :(
So here's my work arround.
For each Email account I have I have two profiles on the iPhone
1) Is the standard profile that was imported from my desktop Mac - with it's incoming and outgoing Email server settings intact
2) Is a new profile - set-up on the iPhone, with the same Email address, same incoming sever settings, and the outgoing Email server set to cwmx.com - I call this my EDGE Profile, as I'll use it to send when I'm on Edge.
Make sure when you build this account on the iPhone that you have the incoming server details and password you'll need, AND that you look at the ADVANCED tab in your Mail settings, and SWITCH OFF SSL for incoming and outgoing.
You need to scroll down to see the advanced tab when you;re setting up a new Email account, so it's not obvious.
Using these two accounts I can:
1) receive any Email to my home POP3 Email address, using the iPhone
2) Reply to that Email using either the first (Mac Sync'd) account if I'm on wi-fi, or my new EDGE account if I'm on EDGE.
Pain in the ass, but it works for now until Apple provide an auto sense work around for the switching over of outgoing Email servers!
Hope that helps.
JASmine
Jun 22, 2007
Or just use the rr webmail for outgoing... A pain for replies but does work in an emergency
Ryukyu
Jun 15, 2007
101
cdodkin,
That works except if you want to reply to an email that is already received in your WiFi profile.
Is this an Apple issue or is it a Roadrunner issue?
invincible569
Jun 30, 2007
79
cdodkin,
It's not an issue, but a security block to prevent unwanted spammers to relay off of TW. Apple has nothing to do with it.
On enterprise email gateway servers, you can allow domain names (ie. ATT.net) or a range of IP's.
Ryukyu
Jun 15, 2007
101
That's what I thought. So there isn't anything that Apple can really do about it if Roadrunner will not cooperate.
In that case, can anyone tell me how I can forward my Roadrunner email to another domain address?
invincible569
Jun 30, 2007
79
That's right. It's a custom addition instead of the preprogrammed email accounts they had built in. Im sure over time, Time Warner will change this. Hopefully one of the executives will buy an iPhone themselves experiencing the same issue which will expedite this fix.
You can set a rule in Outlook, but your computer must remain on at all times. I haven't seen anything under Roadrunners settings to fwd unless I missed it somewhere.
Ryukyu
Jun 15, 2007
101
I found out that if you log in to your webmail account, you can look at Options, Settings and set a forward in there.
purequartz
Jul 2, 2007
As much as i want to love this phone, the longer I have it the more frustrated I get with it. A great toy..but not for $600.
purequartz
Jul 2, 2007
I have the same problem with roadrunner, not able to send from the phone. Also my work email doesn't "work" at all where I never had a problem with the blackberry.
Webpages with animated gifs don't work as well (even these worked on my blackberry). Trying to get a good weather radar with animated loop, but none seem to work.
Hondamaker
May 14, 2007
9,946
655
61
Fairborn, Ohio
Same issue here!
Hope that helps.
That's slick! It's also the best workaround I've seen so far. Thanks!
Ryukyu
Jun 15, 2007
101
OK, WTF!
When I try cdodkin's approach, the iPhone switches everything. I name one EDGE RR and the other WiFi RR. check the two and everything is fine.
Then I leave the settings and return to the home screen, go to email, and both are named EDGE RR. Go back to settings and both have the EDGE profile settings.
Anybody have any idea why it would match the two profiles up?
Simon Templar
Jun 30, 2007
39
Infinite Rider On The Big Dogma
RR Support: You cannot send email over the Road Runner outgoing mail server unless you are connected to the Internet using Road Runner.
Perhaps I am dense. But is this the reason that...when I try to send... I get a failure message saying 'the recipients address was refused by the server'?
This seems to indicate that RR would have accepted it save for some problem with whom it was addressed to. Yet...it does this regardless of who you send it to.
.....sT
Ryukyu
Jun 15, 2007
101
.....sT
That is correct.
To me, it's a huge problem. There are many threads about it over at the Apple discussion boards.
The solution was to create two different profiles, which I did, but for some reason the phone just decides to change the settings to match both profiles.
This is just maddening!
cdodkin
Jul 2, 2007
305
SoCal
www.d30-images.com
Not seen the problem where the two accounts rename/re-configure
You did have different outgoing server settings in each one didn't you?
May be worth doing a soft reset - home button + sleep button together for 5 seconds - then try the account set-up again
