"Settings icon " vanished
jaygee27
May 31, 2009
I installed a third party application - applied a crack thro WinSCP 32 & rebooted iPhone, After Bootoing the "settings Icon" vanished. I had no solution in the website to get back the settings icon. Can I get back it without reinstalling the OS.. --- Srikar.Jaygee27
5,405
If it was any other app that disappeared, I'd say to into settings and then choose reset all settings. Try removing the app that caused the problem. Otherwise, you may have to restore the phone.
BTW, discussing cracked apps is a voilatation of forum policy.
jaygee27
May 31, 2009
Thanks for the suggession. AS the "settings " itself has gone I had to Restore the OS
no other option
wjp09
Feb 25, 2007
2,559
25
NJ
Do you have boss prefs installed? Check to see if Settings is being hidden by POOF!
