Sirius on iPhone
Dannnn
Jul 26, 2007
I haven't tried this yet but I'm going to monkey with this tonight.
http://howardforums.com/showpost.php?p=9582097&postcount=1
I have also thought the ultimate portable audio/music device would be a Sirius receiver and an Ipod.
Well after reading a couple of other posts on this topic I can now hear Howard Stern live on my iPhone!
You need the following:
1) http://www.millardsoftware.com/uSirius (this runs on your local PC and connects over the internet to Sirius using your Sirius account).
The setup is pretty straight forward - just enter your Sirius account info and it will do everything else. Click on URLs to get the URLs for each Sirius channel you want.
2) Sign up with http://orb.com/ and install the local client on the same PC that you installed uSirius.
3) Set up Internet Radio Favorites on mycast.orb.com (cut/paste the URLs from uSirius for Howard 100, 101) for each Sirius channel you want.
4) Login to mycast.orb.com from Safari on your iPhone and select the favorite that you created. Listen away!
It works well over Wifi. However, I have to wait to go back to the states to see how well it will work over Edge on ATT as it's too expensive to use on Rogers, currently
Note there seems to be a bug, on the first connect from Safari, it will crash, just try again and it will stream quite well for a long time.
OH BTW live365 Internet channels also work in the same manner (Get the URL from iTunes get info after trying on your PC). iPhone also works well as a remote control for my SqueezeBox.
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
I can listen to Sirius live!
you don't need flash. Read the instructions above this post. A guest of howardforums wrote that a few days ago. The software downloads are simple and its all free. I've bee listening to HOWARD stern all night. The only tricky part isadding the URL to the orb Internet radio favs. I'll poztscreen shots tomorrow. And if any of you are stuck and need help just reply here. It will buzz me and I'll reply in a few minutes as long as I'm not sleeping
brittt1
Jul 17, 2007
68
I have a couple of issues with this working:
1) USirius will not connect to server (says bad name and password, but the name and pass work when i log in to Sirius directly) is this related to the fact that you have to enter the text/numbers from the image when logging into Sirius direct?
2) Orb will not recognize that it is running on my PC (which it is) keeps saying you must have orb installed and running...
drconehead2000
Jul 2, 2007
98
I just set this up to listen to my Sirius...man does it work great...finally a solution that allows me to listen to Howard where ever and whenever I want! Thanks for the post
ps49556n
Jun 21, 2007
545
NYC
Holy crap this just made my day if this really is true.........I have been waiting for a solution to this for ever!:laugh2::laugh2::laugh2::
I am going to try it out later and if this works as described I will be the happiest person alive.:p:p:p
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
Are you entering in a user name for uSirius or the email? And youre going to uSirius settings to enter the info in?
420greg
Jun 26, 2007
845
Orlando, Florida
Sorry, but could you explain what that means?
A CAPTCHA is a type of challenge-response test used in computing to determine whether the user is human. "CAPTCHA" is an acronym for "Completely Automated Public Turing test to tell Computers and Humans Apart".
Or in other words....
The letters and numbers you have to type to log in to a bunch sites.
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
i don't know if it has a catpha thingy but it works just fine. uSirius access the radio channel for Sirius via your user name and password from Sirius. then you take the url from uSirius and paste it in the internet radio favorites in orb. you have you have your computer on and uSirius running to stream the music, but you can stream it anywhere in the world. you guys couold even use my Sirius stream to listen to howard, you wont need your own account. just download mycast.orb.com and ill give you the link to post in your internet favorites so you can see for yourself.
Coolstrategist
Jul 10, 2007
84
I followed the instructions and now I have streaming Sirius channels. Very nice!
I did not have a single problem. But you are correct that there is a bug that causes a crash when you first start streaming. From then on it is GREAT.
Thanks.
LD3
Jun 29, 2007
The simple instructions worked great for me. I have been wanting to get Howard on Sirius since I purchased the iPhone. Works perfect on wifi. Great tip! ++
brittt1
Jul 17, 2007
68
ok im an idiot forgot the Sirius internet pass was diff to the Sirius log in pass...
JiggyMatt
Jul 6, 2007
152
Las Vegas, NV
www.myspace.com
Ok so open uSirius and click settings. Then enter in your Sirius user name, NOT EMAIL. Then enter in password. don't enter in anything else. Try that. It still not working then uninstall uSirius and re install after you reboot pc. Your on pc right? I don't know if it works with mac. Once connected it will say so in the box with all the writing but nothing other than that should happen. Let me know if your still having trouble after that.
brittt1
Jul 17, 2007
68
Ok i have it all working...well not really...
I have USirius working and running
I have Orb running
I have created a customs internet radio link and pasted the http URl like:
http://192.XXX.X.X:19080/feeds/lineup.xml?bandwidth=low&category=cathowardstern&genre=howard100&r=1186113037
now when i go to my iPhone log in and click on my made Howard 100 link it plays a 1 second quicktime and that is it.. I do see the request coming into the uSirius server and the server running, but after the 1 second thats it, nothing...Now i can stream one of the ORb stations just fine (BBC)
any ideas what i have missed?
brittt1
Jul 17, 2007
68
Sounds like you got it working. It sometimes freezes. Try clearing safaris history cache and cookies. Restart the phone and then try again. That should work
nah, did all that and it still isn't working..maybe im just doing the setup in orb wrong, url etc ...too tired to figure it out now...thanks.
