Get a smaller cheek. Don't take that to heart I was just joking.I can't seem to get this to work for me. I have the Verizon iPhone and went in and turned Facetime off, even rebooted my
phone and still no ""Hold"" button. I am all the time ending calls due to my cheek hitting the end call button. What could I be doing wrong?
Thanks so much for your help "-)
I had the same sort of problem I found a solution to it by getting a jawbone icon. It's a bluetooth headset, I know there not for everyone but it has since helped me a lot with that sort of issue.LOL, thanks just the answer I was hoping for !
Yep... this still bugs me. Stupid FacetimeWhile on a call, tap and hold the mute button, it will put the call on hold (mute will change to hold). It will also work on the Verizon iPhone.
Thanks All, appreciate your replies, I tried the tap and hold for mute and guess that is to complex for me to do cause
I still can not get the "hold" button to come on. *&! .... I will keep trying, I am only tapping once then pressing down mute but it doesn't change. Grrr
Unless I'm just not doing this right, it isn't working on my Verizon iPhone 4.Touch and hold mure for like 2-4 seconds. It'll (should) change to hold when you let off your finger.
