Can someone post a link to the map again with instructions on how to place a pin.
ive tried it several times and can't seem to firgure it out.
Alright. Here's a short tutorial to placing your pin on the iPhone map.
Go to
Google.
Select the sign in link at he upper right hand corner of the Google page.
Now you should be
here.
Locate the sign in section on the right of the page.
In the Email box, type in:
theiPhonemap
In the Password box, type in:
iPhonemap
Now you should be signed into Google. At the top in the upper right hand corner, you should see:
TheiPhonemap@gmail.com
right next to iGoogle, My Account, and Sign Out links.
Now go to the upper left hand corner of the page. Find and select the Maps link that is right in between the News and Gmail links.
You should now be in Google Maps.
Select the My Maps tab just to the right of the Search Results tab. The tabs are right under the Google Maps logo.
Select the iPHone Campers Guide! link.
Now just click a pin marker and drag it to your location. Make sure to type your details with your user name.
You're done.
Everytime you go back and check the map, it'll be easier because you won't have to sign in anymore. Just go to Google.com and select Maps.
Have fun.
