My quest for the "perfect" holster case continues. I prefer to use my cell phone "naked" (the phone, not me) and I also prefer to carry them on my belt/hip, not in a pocket. That's how I've carried all my previous cell phones and that's how I want to carry my iPhone.
When I purchased the iPhone the only case immediately available that fit my needs was the Griffin Elan Holster:
http://www.griffintechnology.com/products/elanholster/
There it was, right at the Apple store and, quite frankly, it is the one I continue to use (as I look for the "perfect" holster case). But the leather quality isn't that great and I don't care for the embossed design and I'm particularly not happy with the way the belt clip is moveable/removeable. Since it isn't secured down inside the case, the case will sometimes twist a bit on my belt.
Since the Griffin wasn't the "perfect" case for me, I next ordered a Sena Elega Pouch:
http://www.senacases.com/Brands/apple-iphone-Cases/APPLE-iPHONE-ELEGA-POUCH
Outstanding leather quality and outstanding construction. But the sides of the Elega are too tall to allow me to easily grasp the iPhone to remove it from the pouch (Sena should have lowered the sides a bit to allow more finger room to grasp the edges of the iPhone). Plus, the darn "ratchet" belt clip turns WAY too easily. Same problem as with the Griffin... all too easy for the case to become askew. The Elega went back.
Then I got my hopes up over the iQase Swift:
http://www.iqase.com/index.asp?PageAction=VIEWPROD&ProdID=2
That one arrived today. Very nice leather quality and EXCELLENT belt clip design. Unfortunately, the case is much too loose. So much so that a bit of jogging with the case on my belt actually causes the iPhone to bounce up and down inside the case. And, to top it off, the material that iQase used on the sides has a coarse texture and I'm concerned that it might wear the finish on my iPhone over repeated insert/removal from the case.
So, the Swift is going back too and I'll continue to use the Griffin until I find the "perfect" vertical holster case.
If anyone spots one, please let me know. My silly requirements:
* Quality leather
* Soft interior and soft side material (the leather sides the Griffin uses is fine)
* Full coverage for the face and back of the iPhone
* Vertical orientation
* Good belt clip that doesn't twist
* Open at the top (no flap)
* Low enough on the sides to allow easy grasp of the sides of the iPhone
* Nice snug fit that won't allow the iPhone to drop out of it should you turn it upside down
* No giant white logos or other ugly ornamentation
* Good quality interior material that resists bending but remains flexible (the iQase feels like it is simply stiff cardboard inside... the Griffin and the Sena felt more like a firm but slightly flexible plastic material)
I see that iQase is running a design a case contest. The "perfect" case would be the elegance of the Sena combined with the belt clip of the iQase combined with the easier access (grasp) and snugger fit of the Griffin. But that would still be so close to the iQase Swift that I don't see them making a new case. I spoke with the owner and he didn't seem to care about my concerns over the fit and side material quality (too coarse).
Maybe I should just go to a nice leather shop and have them make one to my specifications?
Mark
