hinky,
1. Have you tried a hard reset (press and hold the home and power buttons simultaneously for 10 seconds)?
2. I know you are a PC user; do you have access to a Mac?
3. Is your SHSH on file with Sauriks server?
4. Do you need the unlock?
1. Yes - that reboots
2. Gracias - yes, I can have access to a Mac
3. Unfortunately I don't think so as I may have not done it on this replacement phone (which may mean I'm in trouble as I only have the ID). It's the old boot and not sure if that makes a difference, only regarded untethered when it can be jailbroken.
4. Yes... that's a big part of it.
Many thanks... you're golden trying to help so quickly. Not sure what to do here and I'm not sure anyone is in a position to say. On one side I don't want to update the phone which is/was still at 3.1.2. On the other hand, the phone is a brick indefinitely until this is figured out...
Looked at sn0wbreeze but not sure it really works. Can't find anyone that did and going to 3.1.3 is a big risk as per Mr. Blackra1n.
