WiFi issues
Diane B
Apr 20, 2010
72
I was set to buy the 64GB wifi only as we have Verizon Palm Pre mobile hot spot when needed, but the wifi issue has kept me from clicking on the buy button. I think I will wait just a bit and continue with my Touch. I'm a future Ipad buyer for sure, but really don't want to deal with wifi issues since my Touch is so sure to work all the time with every network I've come into contact with.
Michael Baturin
Jul 11, 2007
1,751
244
South Jersey
Just a note. Most iPads connect to wifi without issues. I would say a small percentage of people come across this problem and I have heard a visit to the Apple store will yield you a replacement fairly easily. I am not convinced it is a design flaw. I believe some units just have defects. Out of 1M the are bound to be some rejects :)
Diane B
Apr 20, 2010
72
Yes, I tend to agree that there will always be some problem units but I don't live near an Apple Store so it will mean sending a unit back, etc. On my photo forum, no one has had a wifi problem of any importance though they are struggling with some other issues related to uploading with camera connector, deleting RAW (camera) files, etc. I could buy from Best Buy where I could exchange if needed but they are totally out, so I sit and wait LOL.
connie
Jul 11, 2007
2,839
105
So Cal
I've had my iPad replaced, I'm convinced it's a bug not the iPad itself. It needs to work on wifi just like the iPod touch does. They need a fix. I looked at all the fixes on Apple forums but again I don't know how to change settings or whatever on Veriizon Fios. I just need the iPad to work with it like everything else does!
leslivres
Mar 31, 2010
123
it doesn't take much to "trip the switch" and my problem was that i had no idea how to "fix" the initial problems i had. was afraid to change settings, etc. Eventually it just worked the way it was supposed to and i am more than grateful! i did contact Apple; my ISP provider and anyone who I thought could walk me through it. they just did not have an exact answer. it just took care of itself.
hope it works out for you...soon!
Wiggo
Jul 7, 2007
103
Memphis
Since my last report, my iPad has dropped the wifi signal a couple of times, but it just pops up the dialog to connect to a network, I tap my ssid, and it reconnects. No more asking for password!
And of course, my 3G iPad arrives tomorrow, now that this one is finally working.
dcom
Aug 7, 2007
1,421
Suwanee, GA
My WiFi problems have improved. I have 2 networks, one is an 802.11g running off a Belkin router and a Timecapsule set to 802.11n only. I noticed that when I had the iPad connected to the Timecapsule net, I'd have intermittent and weak connections. Then I noticed a pattern.
Whenever the cordless phone was in use, I was seeing 1 bar on the WiFi indicator and sometimes the connection would appear to hang,a lthough it wouldn't really disconnect me. If I switched over to the Belkin net, the connection would stay pretty solid.
I remembered that our phones operate somewhere in the 5GHz band, potentially the same as 802.11n, so I modified the Wireless setting on the Timecapsule to use a Narrow channel, which reduces interference from other wireless devices.
Voila! The iPad now has a much more reliable connection to the Timecapsule net and using the phone does not appear to degrade the signal.
So, if you're having issues with your connection, see if there is a setting on your router to reduce interference from other devices.
connie
Jul 11, 2007
2,839
105
So Cal
That's really cool you figured it out. I just don't get how to change the router stuff. You might as well have been speaking another langauge because I have no idea what it means. It's all foreign to me. I'm so not technical when is comes to stuff like this.
flabyboy
Jun 25, 2008
769
Minnesota
What kind of router are you using? All routers have a URL address that you type into your browser. It usually asks for a user name and password that you could find easily using google. Once you find that you will come to a setting page where it will have available firmware updates and all the settings we have been discussing. If you want to send me your router make and model I could look it up for you
damstr
Jul 2, 2007
133
Mine has the wifi problems but only when connecting to certain routers. Verizon fios routers this thing definitely doesn't like. Always have to enter the wep key.
Since replacements seem easy to get I think I will utilize this since my ipad has a scratch on the screen already. :(
connie
Jul 11, 2007
2,839
105
So Cal
The router is a Verizon MI424WR. Unfortunately I've already been on the Verizon forums where people have tried different settings, channels, etc. and it's only a temporary fix. They stop dropping signal for awhile but then have to enter their internet password again. There is actually a Verizon tech on there answering questions and he says it has to do with the antenna thats located behind the Apple on the back of the ipad. He said that if thats laid flat it loses signal and its an Apple hardware problem?
flabyboy
Jun 25, 2008
769
Minnesota
I really doubt its a hardware issue at this point. Mine works flawlessly and much better than my iPhone. I have heard the Verizon routers are having troubles.
bambam26
Sep 7, 2007
119
Atlanta, GA
I have the same issues, I think the reason most people that I am seeing are having issues and some are not is because of the different routers. G routers that are putting out 20Mhz signals are not having issues, N+ and G routers that produce a two signals at 20 MHz and 40MHZ have problems. If you have a true dual band router that splits the signal into two separate signals these are not having problems unless the N signal is at 40MHZ in which case you will have to change it 20 MHZ. To recap.
1. Run your router at N only 20MHZ
2. Run router at G, B, A only at 20 MHZ
3. Run (Dual Band Routers only) N on one Band and G,B, and A on another band. Connect iPad to N band only 20 MHZ.
The iPad does not support 40MHZ signal, I have no idea why this is. You would think that Apple would have noticed this problem from the start. I will say that this can be attributed to the fact that they only have Apple routers at their site I am assuming. I have done my on test and found that of the 5 iPad that my friends have all have the same problem, but when we connect them them to a Apple Airport there is no issue. No dropped signals. This is my second iPad I exchanged one at the store when I first got it. Same problem so getting a new iPad is not working as a fix. The 5 test subjects for lack of better words range in purchase date from launch date to this past Saturday the 22nd. 2x 16gb 1x 32gb 2x 16gb 3g.
chris
Administrator
Administrator
Jun 10, 2006
11,818
1,710
Long Island, NY
That's pretty interesting. I looked at my Verizon FIOS router setup, but not sure how to change the signal from 40Mhz to 20Mhz. I currently have it set to g only -- but I still experience drops, requiring me to reconnect (re-enter password).
Diane B
Apr 20, 2010
72
Wifi
Got my 64GB wifi this morning a week early. I hoped that I wouldn't have wifi issues and so far none. Our house is. Ig and old (100 yrs +) with thick walls and quite a few in some areas away from the router. I can even get a connection up at our pool a distance from the house. The router is an old Linksys G
I'll be interested to see how it goes in other situations. For now though I love the Ipad. I expected to having tried one several times and using a Touch all the time
bambam26
Sep 7, 2007
119
Atlanta, GA
I looked through the manual for your router and I am not seeing a option to change the frequency strength. This leads me to believe that your router is 20Mhz. What security are using, I forgot to mention in the above post that the iPad at least from our experience is not a fan of WEP. So WPA or WPA2 or a combination of both is better. Also when before you connect to your network after you make changes go into wireless settings and for your network choose forget network. Then basically reconnect to it like it was the first time. Hope this helps. Feel free you send me a message on here if you have more questions. i will be glad to help you. This Wifi thing will drive you nuts.
danamark
Mar 3, 2010
90
wifi problems
Noticed my wifi problems went away via of going to wpa from wep. Then noticed my wireless backyard security webcam was not working, runs all the time, along with a wired one. Checking on the webcam, it can only do wep, no joy here, so changed back, got the wifi drops every 4 to 10 minutes. Ran speed test from ipad, Getting download speeds like 3.17 Mbps, 4.97 Mbps, unplugging the wireless webcam, 9.02 Mbps, 8.96Mbps, this is on a 10.00Mbps FIOS, on a G wifi network. With the webcam off I get just a few, or zero wifi drops. I noticed too with the wireless webcam on, safari was taking a long time to display a long web page, like when you have a weak signal. So, you get the problem when your bandwidth goes to 1/2? Or when the bandwidth goes below 5 Mbps? Just guessing, but, it is interesting. Anyone else check their speeds? Do you have good speed, but, still have the wifi problem?
edit, Should note my new HP laptop, which run wireless G, has no issues with dropouts, if the webcam is off or on.
L
lilcy
Guest
iPad wifi and 3G
I think it may be an iTunes bug. I'm having trouble with it as well. Hopefully they'll have an iTunes update soon.
Yeah, maybe. But now there are solutions, doesn't it?
I read some news that Apple replied the problem, and there are some solutions supplied.
And I runinto this article "Tips to Turn iPad Wifi Into 3G" said some tips on how to get your iPad WiFi connected to 3G, maybe make some difference for wi-fi users.
source: LINK REMOVED
dirt_mover3g
Nov 3, 2008
34
Hello everyone, im having a hard time getting my linksys router (model: befw11s4 ver.4) to work with my iPhone. I can connect to the router no problem and my wifes iPhone can as well, but when we go to safari (or any app that requires internet) it takes FOREVER to load, if it ever loads at all. In safari it pops up saying Cannot Open Page because the sever stopped responding. Every now and then it will catch the signal and load the page, but i would say 9/10 times it doesn't. I have a laptop and a desktop that both have no problems at all when hooked up to the wifi. Both my wifes and my iPhones can connect to other wifi routers with no issues at all so its not the phones (at least not with the hardware).
Is there some settings i can change that will make it work? Im not familiar with this kinda stuff so please be gentle on me;) thanks in advance!
-Brandon
