winpwn released for 2.0
R6andbmw330ci
Jul 13, 2008
20
might not be the best source to use, it was posted on Wednesday, 7th May 2008
Here is the guide just posted for the 2.0 unlock with winpwn
http://www.iclarified.com/entry/index.php?enid=1572
I just followed those steps and successfuly unlocked and jailbroke my V1 iPhone which was/is running 2.0 software. I've never done it before and I had no trouble so it seems pretty dummy proof (if you follow the steps)
i'm in the process of following this. this is my first time
thabayboy52
Jan 27, 2008
52
ok so i jailbroke my 3g iPhone with cydia installed but my phone does not get activated... i give up until they make more bug fixes
faseone
Oct 2, 2007
203
when you build your custom ispw.. make sure the only thing checked is cydia.... do not activate youtube.. or on advanced have activate checked.... THE ONLY THING THAT SHOULD BE CHECKED IS CYDIA...
(this is if your att) which being 3g you are.
thabayboy52
Jan 27, 2008
52
i did everything right, only thing that is checked is cydia. i just get no service when i jailbreak it
umakbill
Aug 17, 2007
39
I followed these instructions, and successfuly jailbroke my 1st gen firmware 2.0 iPhone, but iTunes could not restore it from the backup so I need to undo all of that and do a fresh restore from DFU mode. Gunna wait a little longer until they have this perfected before trying again.
jimmyrules712
Sep 21, 2007
264
I miscommunicated a bit. The link I posted was only for 2G AKA V1 iPhones, not 3Gs. If you used that link of instructions and are having problems then that is most likely why.
I differentiated between the 3G instructions and the V1 instructions in my post here:
http://forums.everythingicafe.com/threads/instructions-to-unlock-jailbreak-v1-iphone-and-jailbreak-3g-iphone-for-windows-users.28988/
If you did the wrong one on your 3G you should be fine, just go through and re-do it with the 3G instructions
itsnowornever
Jul 20, 2008
267
Cali Baby!
OK...cool! Thanks!
thabayboy52
Jan 27, 2008
52
if there are any of you with 3g iPhones trying to jailbreak using winpwn go to the advance setting when creating your IPSW and UNCHECK activate phone. you will have service after jailbreaking
Popdevil
Jul 2, 2007
254
If you go step by step it works. I missed one section and got confused but figured it out.
The only problem I have is YouTube needs to be activated it says. I'm going to do it again and see what happens.
itsnowornever
Jul 20, 2008
267
Cali Baby!
OK----so I think I got all the downloads I need for the 3G---however, for the 1st Generation of the iPhone it says to download the bootloaders, it doesn't meantion that for this one. Did he forget that step, or do I not need to bother with that? Will this let me change the background of the home page?
thabayboy52
Jan 27, 2008
52
if your using 3g you do not need that step... are u using winpwn 2.0.0.3?
Popdevil
Jul 2, 2007
254
I've been reading your posts over the last few days and see you are trying to jailbrake your phone for the first time. (or it just seems like it). Good luck and hope it works out for you. I've done the jailbrake since the 1.0.2 (or something close to that).
Just make sure to have a good backup of the phone.
FYI: I got mine working now and have the one thing I missed which was the ability to change teh TEXT MSGS sound. (Seems too simple to go through the jailbrake process but I had to have it)
mac3194
Jul 21, 2008
9
i jailbroke my 2.0 i restored from back up and i still have no service please help:(
Chris.Carter770
Dec 25, 2007
99
If your a AT&T Customer, you do not need to select activate iPhone in advanced settings. You must creat the ISPW without that selected and it will then work
